Error[e16]: Segment IDATA_Z (size: 0x58 align: 0) is too long for segment definition: IAR workbench
Hiroshi_S
Junior Member level 1
I have imported the AT89S52's Keill's c code to IAR workbench, after compiling I am getting this error but in keil it's not showing such error.
/***********This is the error************/
Error[e16]: Segment IDATA_Z (size: 0x58 align: 0) is too long for segment definition. At least 0xf more bytes needed. The problem occurred while processing the
segment placement command "-Z(IDATA)IDATA_I,IDATA_Z,IDATA_N=08-_IDATA0_END", where at the moment of placement the available memory ranges were
"IDATA:b7-ff"
Reserved ranges relevant to this placement:
IDATA:8-9 VREG
IDATA:a-1f IDATA_I
IDATA:21-ff IDATA_I
BIT:0-7 BREG
BIT:80-97 SFR_AN
BIT:a0-b7 SFR_AN
I also think as suggested in error message, it required 0xf more bytes, if we extend this memory, maybe it will be resolved but if to extend the memory, how to do it?
I am new to IAR workbench, Guys kindly give your suggestions and corrections.
I tried to reduce the number of global variable and then I got this new error.
Error[e16]: Segment ISTACK (size: 0xf0 align: 0) is too long for segment definition. At least 0xef more bytes needed. The problem occurred while processing the
segment placement command "-Z(IDATA)ISTACK+_IDATA_STACK_SIZE#08-_IDATA0_END", where at the moment of placement the available memory ranges
were "IDATA:ff-ff"
IDATA:8-d VREG
IDATA:e-1f IDATA_I
IDATA:21-b6 IDATA_I
IDATA:b7-fe IDATA_Z
IDATA:ff-ff ISTACK
BIT:0-7 BREG
BIT:80-97 SFR_AN
BIT:a0-b7 SFR_AN
Error while running Linker
Now my error changed to IDATA to ISTACK. Does anyone have any clue how to resolve it?
AT89S52 has 256 Byte total RAM available. You have to think carefully how much can be assigned to stack and variables. It looks like your application still needs more RAM than the processor can provide. Without knowing the application details, we can't decide if it can ever fit a 8052. You may want to switch to a x51 derivate with more memory.
Well, I agree with you. I have done this code successfully in Keil software and hardware is working fine and not i am porting it to IAR workbench, this problem occurs, that's why i am puzzled
O.k., if the code is working with 8052 in Keil, it should also in IAR. There are probably different memory assignmentsor may be different memory usage defaults of the run time library. You need to understand how the memory is used in Keil compilation and how to port this settings to IAR.
yes.. i got to this point and got stuck. it would be great help if i get little push in this .. I have attached the both ide settings below.
Please look into it, if any clue you get kindly help me to understand.
I'm not familiar with x51 IAR, but some settings are probably inappropriate, e.g. reentrant function calls, constants in RAM.
yeah, I noticed too. I am going back to level one to understand again.. hmm..
