Error(175005): Could not find a location with: IO_FUNCTION of GPIO (1 location affected)
rafimiet
Member level 5
Member level 5
I am trying to use the HDMI Out port of Intel Arria 10 FPGA board. I am using a pattern generator, and a serializer and finally the out is used to derive the desired output pins. It is showing the above mentioned errors.
The desired files and the complete quartus project are attached.
  • hdmi-master.zip
