Equation to calculate microstrip feed line
ice.deepcold
Junior Member level 1
feed line equation
Hello,
Is there an equation to calculate the feed line of a rectangular microstrip path either for a 50 or 100 ohms.
thank you very much
Re: Microstrip feed line
here are two examples
chemandy.com/calculators/microstrip_transmission_line_calculator.htm
chemandy.com/calculators/microstrip_transmission_line_calculator_IPC_2141.htm
thanks
but I'm looking at something that has formulas and i want to calculate the width of the feed line not the square patch.
Thanks
ice.deepcold said:
thanks
Thanks
hi balanis antena theory book thay have give example problem
REally!
what frequency are u using for ur example?
ice.deepcold said:
REally!
10GHz
Added after 4 minutes:
ice.deepcold said:
REally!
how to find air gap width for a batch antenna feed any way?or formula or thump rule?
In what section of the balanis book is the formula to calculate the width of the feed line.
thank uuu
Check Pozar's Microwave Engineering book, any edition.
thank uuu
chapter14
Hello Sundar,
I got the problem which you told in balanis. But how do u calculate g12? bcoz that is required or calculating the feed point.
