equal scaled y axis with two graphs
Ave
Hello,
I have two different graphs beside each other by subplot but I need to make the vertical axis with the same scale in both graphs, I have tried few options it is not working for two graphs as it daes for one graph.
Does any one have any idea how to make it?
Cheers,
Ave
in excel its easy.
the second data set properties are applied to the secondary axis
then select one y axis & choose manual for all ;min, max , major and minor incrments
then repeat for axis.
for Open Office Scalc.exe do same except choose max, min, increment and number of subdivisions.
For MATLAB, who knows ( F1 ;)
I have two different graphs beside each other by subplot but I need to make the vertical axis with the same scale in both graphs, I have tried few options it is not working for two graphs as it daes for one graph.Ave
I presume you are working in matlab ? In other software like excel it is still easier.
To do that in matlab,you need to know about handles & how to play with them.
Say you have two subplots subplot(1,2,1) & subplot(1,2,2).
Take handles of both of them & set their axes properties using set command
For your case it turns out to be set(H,'YLim',[min,max]); use this set command where H is the handle of subplot whose properties you want to change.
Reactions: Ave
    Ave
