vreg
Member level 4
Hi can someone help me with this question
Design a 8051 based EPROM Programmer to program 2716.The EPROM can be programmed by applying 25V at VPP and 5V at OE pin. Initially all data of EPROM will be 1’s and the user should make the bits zero selectively. Before the EPROM location is programmed it must be checked for whether it is empty (data in location must be FFH if the location is empty) The 8- bit parallel data is applied to the data pins of EPROM. The address for the EPROM is to be provided. To program the address of each location to be programmed should be stable for 55ms.When address and data are stable, a 50ms active high pulse is applied to CE input. (Note: the normal system bus of the processor cannot be used for providing address/data/CE during the process of programming)
How do you keep the address of each location to be programmed stable for 55ms?
How do you provide a 50ms active high pulse ?
