epicprog single layer design
nebisman
Full Member level 4
Full Member level 4
Uploaded again for those who write me
icprog propic software is lame
if you look at icprog
this app will allow that programmer too program most pics {most is 80+% of them}
but you need too add some soic sop etc sockets also on an adapters you can make up
the details are easy and new chips arent too hard too add as they will conform too one another algurithm
my advice is too forget the programmers own software
the older licence key gen dosnt work and produce a correct code
{from the same root as the author} this gives him the ability too shake off the keygen guys
and only then program 0000 0000 too the chip
when using win xp version {only one that runs from win xp}
however icprog dosnt suffer from this
details are avalible on the net too configure icprog too use the above programer
until the keygen is fixed ...!!! hint hint!!! then i recomend using icprog only....
as it runs perfect ....
and also
what a nice design of board well done
i made one on vero board
i did however make a epropic2 an epic and a propic in one
with icp and other sockets
but just using some plain sockets {cheep} and a plastic case
never let me down.....
Nice work
Nice work nebisman i agree with my friend why not ic prog at movment this is nice programmer and can support almost every hardware in the world i also upload a programmer pleasde check it
keep it up like these thing
regards
khalid
yes with the epicwin 2.41 beta, we can program mostl of microcontrollers, I upload other circuit for propic2 ICSP, that works with ICPROG. I like it too(ICPROG) friends.
thanks
nebisman
yes! i have some software,i post to
