Enviroment (RH8) Setup for MENTOR Applications HELP
gezzas525
Full Member level 3
Full Member level 3
The IC FLOW software requires some enviroment variables, assuming I use the c shell what file/s do i put these. Also does anyone have a list of all the variables that are required so far I have the following.
MGC_WD
LM_LICENSE_FILE
LANG
MGC_LANG
MGC_HOME
MGC_TMPDIR
MGC_LACATION_MAP
However I still cannot invoke any of the applications from the console for example typing da_ic does not work but $MGC_HOME/bin/da_ic does???
Also I think I also have to setup the libraries for generic components or something as its giving an error about if not finding generic components.
Thanks help much appreciated.
KLEOS
follow the mgc_install.pdf
where do i get this pdf?
thanks
KLEOS
after the installation, it resides in your installation path/shares/pdfdocs
