pmadithya
Member level 1
- Joined
- Aug 30, 2012
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Bangalore,India
- Activity points
- 1,530
Millions of people use sidewalk daily which is a path along the side of a road. A sidewalk may accommodate moderate changes in grade (height) and is normally separated from the vehicular section by a curb.
This project idea is about harvesting pedestrian mechanical energy and converting it into electrical energy.We have already discussed Piezoelectric sidewalk in our post Power generation using foot steps.
Concept :
This project is based on very simple concept which states that when certain solid materials put under a mechanical stress they produce electricity. These materials are known as Piezoelectric materials.Some examples of these materials are Sucrose (table sugar), Quartz and Topaz
Here's a video on how we can harvest energy using Piezoelectric effect
https://youtu.be/Xuw9frP1GNo
How can you generate energy from movement or pressure? A simple piezoelectric disk (the kind that you use as a transducer/sounder) can be used in reverse to generate a momentary voltage. This short clip shows how an LED, soldered across the disks of a piezo, illuminates when the disk is tapped or pressed. Notice that the LED lights more effectively when the piezo is pressed rather than tapped
Concept :
