energy calculation in vhdl??
fena
Newbie level 3
turkey
I need to calculate the energy of an incoming FSK-modulated digital signal. To do that, firstly, I multiplied the signal with itself by a simple multiplier (i.e. squared it), then, for the integration part, I summed up the first 40 elements of the signal and for every next squared input, I added it to sum and substracted the earliest input (i.e. 40th). However, it seems like not working. I tried to change the value 40 but didnt work What is wrong with my logic? my vhdl code for this part was as follows:
process(clkin)
variable cnt,flag : integer := 0 ;
variable toplam : integer := 0 ;
begin
if clkin'event and clkin = '1' then
if cnt=39 then
if flag=0 then
outp<=to_signed(toplam,22);
flag:=1;
else
toplam:=toplam-my_integers(0);
my_integers<= 0 & my_integers(39 downto 1);
my_integers(39)<=to_integer(signed(datain));
toplam:=toplam+my_integers(39);
end if;
else
my_integers(cnt)<=to_integer(signed(datain));
toplam:=toplam+to_integer(signed(datain));
cnt:=cnt+1;
end if;
here, my_integers is the vector that I store the squared inputs, datain is the incoming squared data and toplam is the current sum.
hi, as per my knowledge in vhdl the code you have written is having some mistake. i ahve pasted a part of your code below. All statements in one process (which are assigned to the same event) gets updated simultaneously thats why you cannot assign single variable or signal different values at a time e.g. for variable toplam you have assigned different values at the same time so it will not get modified or execution of that may affect your other statements also.
if flag=0 then
flag:=1;
else
end if;
else
so sorry. there sohuld be another "end if" statement in the end. I forgot to copy that part.
My code was actually like this:
if cnt=39 then
if flag=0 then
flag:=1;
else
end if;
else
cnt:=cnt+1;
end if
end if;
