roy_ece
Member level 3
Hi ,
when i try to use encounter 8.1 version to load my design, I am getting the following error.
system details:
My system is linux9.0, the kernel version is 2.4.20-8, my encounter version is 8.1
logdump:
<CMD> fit
<CMD> setDrawView fplan
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(syStackTrace+0x132)[0x5deed63]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter[0x11a65df]
/lib64/libpthread.so.0[0x352800eb10]
/usr/lib64/libX11.so.6(XTextExtents+0xf)[0x35290442cf]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z14winTextExtentsP7winsWinP9winsLayerPcPiS4_S4_+0x90)[0x5062f3e]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z16winDrawTextInBoxP7winsWinP9winsLayerPcP6sysBoxici+0x188)[0x509732a]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter[0x507b6a9]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter[0x507c21b]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter[0x5078f17]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z20winViewListIterationP7winsWini+0x108)[0x50662ec]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z13winDbDrawViewP7winsWin+0x97)[0x50865a7]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z11winDrawViewP7winsWin+0x19)[0x509f3f9]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z10winDisplayP7winsWin+0x8c)[0x5061bcc]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter[0x5064310]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(TclServiceIdle+0x4b)[0x6e236db]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(Tcl_DoOneEvent+0x14c)[0x6e1609c]
/usr/local/Cadence/SOC81/tools/lib/64bit/libtq.so(_ZN17TqEventDispatcher13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0xc0)[0x2ac301d78d66]
/usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x28)[0x2ac300dbdf18]
/usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x69)[0x2ac300dbe029]
/usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0xb0)[0x2ac300dbfe90]
/usr/local/Cadence/SOC81/tools/lib/64bit/libtq.so(_ZN13TqApplication4execEv+0x2c8)[0x2ac301d7b31a]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_Z7fe_mainiPPc+0x2ea)[0x118afd2]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(main+0x72)[0x118b088]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x352741d994]
/usr/local/Cadence/SOC81/tools/fe/bin/64bit/encounter(_ZN11QFileDialog6acceptEv+0x512)[0x118a7aa]
pstack
Thread 4 (Thread 0x41a57940 (LWP 14789)):
#0 0x000000352800e1c1 in nanosleep () from /lib64/libpthread.so.0
#1 0x00000000019e8ccb in rdaiLicRecheck(void*) ()
#2 0x000000352800673d in start_thread () from /lib64/libpthread.so.0
#3 0x00000035274d3f6d in clone () from /lib64/libc.so.6
Thread 3 (Thread 0x42458940 (LWP 14790)):
#0 0x00000035274cd212 in select () from /lib64/libc.so.6
#1 0x0000000006e33e4d in NotifierThreadProc ()
Thread 2 (Thread 0x42e59940 (LWP 14791)):
#0 0x000000352800e838 in do_sigwait () from /lib64/libpthread.so.0
#1 0x000000352800e8dd in sigwait () from /lib64/libpthread.so.0
#2 0x00000000011a6a1d in ctrlCHandle(void*) ()
#3 0x000000352800673d in start_thread () from /lib64/libpthread.so.0
#4 0x00000035274d3f6d in clone () from /lib64/libc.so.6
Thread 1 (Thread 0x2ac3025a3f70 (LWP 14739)):
#0 0x0000003527499fff in waitpid () from /lib64/libc.so.6
#1 0x000000352743c331 in do_system () from /lib64/libc.so.6
#2 0x000000352743c687 in system () from /lib64/libc.so.6
#3 0x0000000005deedc0 in syStackTrace ()
#4 0x00000000011a65df in rdaiErrorHandler(int, siginfo*, void*) ()
#5 <signal handler called>
#6 0x00000035290442cf in XTextExtents () from /usr/lib64/libX11.so.6
#7 0x0000000005062f3e in winTextExtents(winsWin*, winsLayer*, char*, int*, int*, int*) ()
#8 0x000000000509732a in winDrawTextInBox(winsWin*, winsLayer*, char*, sysBox*, int, char, int) ()
#9 0x000000000507b6a9 in winiDrawHInstText(winsWin*, dbsHInst*, sysBox*) ()
#10 0x000000000507c21b in winiHInstDraw(winsWin*, dbsObject*) ()
#11 0x0000000005078f17 in winiHInstIter(winsWin*, void (*)(winsWin*, dbsObject*)) ()
#12 0x00000000050662ec in winViewListIteration(winsWin*, int) ()
#13 0x00000000050865a7 in winDbDrawView(winsWin*) ()
#14 0x000000000509f3f9 in winDrawView(winsWin*) ()
#15 0x0000000005061bcc in winDisplay(winsWin*) ()
#16 0x0000000005064310 in winiTkDisplay(void*) ()
#17 0x0000000006e236db in TclServiceIdle ()
#18 0x0000000006e1609c in Tcl_DoOneEvent ()
#19 0x00002ac301d78d66 in TqEventDispatcher:rocessEvents(QFlags<QEventLoop:rocessEventsFlag>) () from /usr/local/Cadence/SOC81/tools/lib/64bit/libtq.so
#20 0x00002ac300dbdf18 in QEventLoop:rocessEvents(QFlags<QEventLoop:rocessEventsFlag>) () from /usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4
#21 0x00002ac300dbe029 in QEventLoop::exec(QFlags<QEventLoop:rocessEventsFlag>) () from /usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4
#22 0x00002ac300dbfe90 in QCoreApplication::exec() () from /usr/local/Cadence/SOC81/tools/Qt/64bit/lib/libQtCore.so.4
#23 0x00002ac301d7b31a in TqApplication::exec() () from /usr/local/Cadence/SOC81/tools/lib/64bit/libtq.so
#24 0x000000000118afd2 in fe_main(int, char**) ()
#25 0x000000000118b088 in main ()
gdb
Using: gdb
[Thread debugging using libthread_db enabled]
[New Thread 0x42e59940 (LWP 14791)]
[New Thread 0x42458940 (LWP 14790)]
[New Thread 0x41a57940 (LWP 14789)]
#2 0xfffffffe7fffffff in ?? ()
#3 0xffffffffffffffff in ?? ()
#4 0xffffffffffffffff in ?? ()
#5 0xffffffffffffffff in ?? ()
#6 0xffffffffffffffff in ?? ()
#7 0xffffffffffffffff in ?? ()
#8 0xffffffffffffffff in ?? ()
#9 0xffffffffffffffff in ?? ()
#10 0xffffffffffffffff in ?? ()
#11 0xffffffffffffffff in ?? ()
#12 0xffffffffffffffff in ?? ()
#13 0xffffffffffffffff in ?? ()
#14 0xffffffffffffffff in ?? ()
#15 0xffffffffffffffff in ?? ()
#16 0xffffffffffffffff in ?? ()
#17 0xffffffffffffffff in ?? ()
#18 0x0000000000000086 in ?? ()
#19 0x0000000000000000 in ?? ()
#2 0x0000000000000000 in ?? ()
#3 0x0000000000000000 in ?? ()
#4 0x0000000005deed63 in syStackTrace ()
#5 0x00000000011a65df in rdaiErrorHandler(int, siginfo*, void*) ()
#6 <signal handler called>
#7 0x000000000118a7aa in _start ()
A debugging session is active.
Inferior 1 [process 14739] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
*** INTERRUPTED *** [signal 1]
14739: No such process
Regards
system details:
logdump:
<CMD> fit
*** Stack trace:
pstack
gdb
Using: gdb
Regards
