Enameled Wire Types
Polyurethane Enamel Type - Polyurethane Enamel Wire with code UEW and UEWF
has Thermal Capacity of 120°C, 130°C and 155°C has diameter range from 0.08mm to 1.00mm
and can be used in Transformers, Meters, Electronic and Communication Devices.
Polyester Enamel Type - This type of Enamel Wire with code PEW
has Thermal Capacity of 155°C. The diameter range is 0.08mm to 1.6mm.
Polyester Enamel wire can be used in Motors for Household Application and Appliances.
Polyester-imide - Polyester-imide Enamel Wire coded as EIW
has Thermal Capacity of 180°C with diameter range from 0.1mm to 1mm.
This type of enamel wire are used in High Power Motors.
Polyamide-imide - Polyamide-imide Enamel Wire has code AIW.
The Thermal Capacity is 220°C with diameter range from 0.1mm to 1.6mm.
This Enamel wire is used in Small Motors and Transformers.
Self-Bonding Polyurethane - Self-Bonding Polyurethane Enamel Wire with code SB UEW
has Thermal Capacity of 130°C with diameter range from 0.08mm to 1.2mm used in
Communication Apparatus and Small Motors.
Self-Bonding Polyester-imide - Self-Bonding Polyester-imide Enamel Wire with code SB EIW
has Thermal Capacity of 180°C. The diameter range is 0.1mm to 0.8mm. Self-Bonding Polyester-imide
is used in Magnetic Coils and Deflection York Application.
Polyurethane over coated with polyamide - This type of Enamel Wire with code UEW-NY and UEWF-NY
has Thermal Capacity of 130°C and 155°C with diameter range from 0.08mm to 1.6mm
Polyester overcoated with polyamide - Polyester overcoated with polyamide are coded as PEW-NY and PEWH-NY,
has Thermal Capacity of 155°C and 180°C with diameter range from 0.1mm to 1.6mm.
This Enamel Wire is used in Small Motors.
Polyester-imide overcoated with polyamide-imide - This type of Enamel Wire with code EIW-AI
has Thermal Capacity of 200°C with diameter range from 0.1mm to 1.6mm used in
Microwave oven Transformer and Air-con Motors.
Breakdown voltage depends on the thickness of the covering,
which can be of 3 types: Grade 1, Grade 2 and Grade 3.
Higher grades have thicker insulation and thus higher breakdown voltages.
Enameled Wire Type - Chart
http://www.enameledwire.com/enlarge.aspx?q=Images/Types.JPG
http://www.enameledwire.com/properties.aspx
