tux21
Junior Member level 3
i am working with an EMG i.e electromyography amp.
i use 2 x 9V batteries to get +9 and -9 supply with virtual ground in between
i am getting the final EMG output w.r.t the virtual ground i.e 9v above and 9v below it.
now the problem is to interface it with adc0808 and 8051 i have to have max peak to peak range of 5v w.r.t a gnd. Since adc0808 has only one gnd pin connection i have decided to put both Analog and Digital gnds together. I am taking the negative of the 18v supply battery as this gnd.To get the signal within 5v of this ground i use a voltage divider as in fig with R2 and R1 , R1 connected to the negative terminal.
Here v1 can be considered my emg output from amplifier which i wanna attenuate.
The cro can be thought as my adc where gnd probe of channel A is connected to -9v terminal.Some calculations will show that the cro input will range from 0 to approx 7v if taken w.r.t -9v.
My problem is i thought it would be better to add a buffer after the voltage divider so as not to load it down. But by inserting the buffer i get no ac output.I cannot say about dc shifts as i use pc soundcard oscilloscope which is ac coupled. Without using the buffer i get proper output from the adc0808. If i use OP07 instead of LM741 i am getting some positive portion of EMG . I am curious because i never thought i will have problems with a buffer.
ps. R1 is actually a pot from 0 to 500 ohms.
