EMC of eight parallel mini switch mode current regulators.
eem2am
Banned
current regulators
hello,
I am making a LED lamp using eight 300mA LEDs.
It will run off a battery with voltage 13.5V.
I dont want all the LEDs to simply come on all at once,
-i want them to come on in succession, LED "chaser" style.
Therefore, i have designed the following circuit, which uses 8 parallel mini switch mode current regulators (one for each LED).
(I will control each LEDs on/off with a PIC interfaced to each of the current regulators)
https://i27.tinypic.com/1z1zsi1.jpg
These will all be paralleled across the 13.5V input.
My question is.................
Will this cause a Bad EMC problem?,
-since eight switchers (albeit ~one Watt each) will be switching away and may "beat" with each other or something, causing bad EMC problems.?
(These mini current regulators are not synchronized and i may end up using a different (constant frequency) controller than ZXLD1362, which is hysteretic mode.)
emc switchmode
Unsynchronized switchers can be expected to broaden the EMC interference lines and thus cause lower peak levels in emission measurements. If there would be a synchronisation option, the phase should be shifted between individual switchers.
The commutated current between D2 (VIN node) and GND should be bypassed with minimum inductance.
FvM,
what you say appears to make good sense, but my place synchronize the converters for EMC reasons.
Are they wrong?
