embedded web server doubt
ranju4u6
Newbie level 3
Newbie level 3
india
hi,
I am a PG scholar , my final yr project is implementing a web server in w7100 for control applications.
I am new with this kit and I created a socket and I am able to establish connection with the socket.
but i donno how to do the communication part ie, once if the connection is established , how can i send a response to a html page.?
I am posting my main() fuction here......plz help me
void main()
uint8 xdata S_Stat=0; //socket initialization status
uint8 L_Stat=0; //Listen status
uint8 xdata E_Stat=0;
SOCKET s=1;
uint16 port=5000;
//start of initialization part................source TCPIP driver user guide
Init_iMCU(); //initialize the kit
Init_Network(); //initialize the network parameters.
//end of initialization part
//.............................................................................................................................................volatile part
//Data Comm part begins..................source at pg no.107
while(1)
switch (getSn_SR(s))
case SOCK_CLOSED: /* if a socket is closed */
close(s);
socket(s,Sn_MR_TCP,port,0x00); //SOCKET INITIALIZATION;RETURNS 1 IF PROPERLY INITIALIZED
break;
case SOCK_INIT: /* if a socket is initiated */
L_Stat=listen(s); //LISTEN SOCKET (FOR SERVER MODE);RETURNS 1, NORMALLY WHEN SOCKET STATUS REG. IS SOCK_LISTEN(don't know how it works here).
break; //IF SUCESSFUL IT'LL GO TO SOCK_ESTABLISHED STATE.
case SOCK_ESTABLISHED:
if(getSn_IR(s) & Sn_IR_CON) // check Sn_IR_CON bit
evb_set_lcd_text(1,(uint8 *)"Connected from client!!");
setSn_IR(s,Sn_IR_CON); // clear Sn_IR_CON
//send( s,(uint8 *) "HELLO WORLD", 11 ); //PROBLEM HEREEEEEEEEEEEEEEEEEEEEEE............................
break;
case SOCK_CLOSE_WAIT:
disconnect(s);
break;
//Data comm part ends.
//..............................................................................................................................................volatile part ends here
I am getting the output "Connected from client!!" on LCD when i tried https://192.168.0.2:5000/ on ie's url.
how to proceed from here if i want to get an html page as response?
my send function is: uint16 send(SOCKET s, const uint8 * buf, uint16 len);
You have to use the accept API to allow multiple connections and to have something to decode the HTTP requests to respond with the proper action.
In this link **broken link removed**, pick any open source webserver and follow the example of using the sockets.
Amr Ali
thnk you for the reply,
Actually I am not looking for connection from multiple clients, since its a control application.
I managed to put the HTML page into the data memory (00-FF)of w7100.
as I'm not good in pointers I have trouble in sending this HTML page using send fuction( uint16 send(SOCKET s, const uint8 * buf, uint16 len)).
If someone can help me to send the file availavle in the data memory using this send() function, it'll b really helpful.
Can you share the code?
Amr Ali
Hello,
In the w7100 ,256Byte of data flash (00 -> FF) is reserved to save IP SUBMASK, MAC address ect.
not designed to put your web pages
best regards.
Amr Ali
Re. Sure ......
I already shared my main function at the begining of this discussion.
This is where I got stuck.
//send( s,(uint8 *) "HELLO WORLD", 11 ); //PROBLEM here
break;
this is the 1st time i’m doing socket programming. So As I understood correctly SOCK_ESTABLISHED is the condition that we use to communicate with the client(using html).
For that purpose I am trying to use send() function(i need to send an html page back to client).
I am attaching a file which has send() fuction and its related functions , with ERROR lines mentioned by comments.
________________________________________
Hello,
Re. Thnkx for the inf.
But there are seperate registers for IP,GW,SubnetMask etc.........right!!? like SIPR for IP
If the data memory is for that purpose, it’ll b nice if you can give me some information about how can i store a web page in wiznet W7100 & how to access it.
hello
SIPR registry is actually part of the data flash just works virtually 0xFE000000 position, mystery of memory remap jej
regards..
Check **broken link removed** for an example of Bascom-8051 and the W7100. Got webserver running, NTP, UDP etc. etc. But got also problems to get hold of the external RAM with the Bascom-8051 $default XRAM command.
Have fun
Ben Zijlstra
I downloaded bascom and when I compiled I am getting errors like
"Error 8: out of internal memory in file:........".....
how can i resolve this?
You have downloaded the demoversion and it can generate a hex-file of 4 Kbytes.
Or you did not get the last version 1.11.98.
There is flash, 64 Kbyte, 64 Kbyte SRAM, 64 Kbyte TCP/IP-Ram, a bootrom and there is 256 byte dataflash. Got all working in Bascom-AVR except for the 256 byte dataflash. You have to read and write to it through routines in the bootrom.
But I will find it...
Have fun
Ben Zijlstra
