Embedded System Programming????
theasus
Member level 3
Member level 3
For embedded system programming, Which program can I use? (My board will be ARM cortex) I want to write some code for this platform.But I don't know the compiler program for this operation. Do you have any idea?
Hi theasus, i recommend that you use keil uvision 4 u can use the evaluation version but the memory limit is 32 K but it is sufficient to program your microcontroller
Regards,
Keil uVision will be a good option. Just browse through the Browser tree of the Keil installation, you can find many basic examples for almost all peripherals will be listed there.
All the best.
