manve_13
Junior Member level 1
Hello everybody,
I need to design a mobile system, I'm going to use one of this boards,
1st board
2nd board
3rd board
This system will work with batteries and I will use 19" LCD for display.
when I check the Manual of 1st board I saw that its not supporting the 19"LCD with LVDS. So I need to connect via VGA and I need A-D converter and inverter boards, am i right?
The woman whose selling the 3rd board told me that their board supports the 19"LCD with LVDS, is it possible connect the LCD directly to the board with a lvds cable? Do i need an inverter board again?
And i want to install windows ce to this system, what can I use to store data, as i search there is an option as embedded disk. But I don't know what the people use generally at those systems. Is there any cheap way?
Thank you
1st board
2nd board
3rd board
Thank you
