[SOLVED] Embedded PIC18 mplab software-Object file- help needed
manikandan123
Member level 4
Member level 4
Bangalore,India
Hi ,
How do use Object file in Mplab c18? if i use the object file of one program in another program,Is the same memory location Occupied?
I have a boot code and application code. I want to to make memory optimization. So I want to share the common function in both program to avoid same function written on both code? the boot code runs at initial and reprogramming time only. is any suggestion?
Thanks in advance.
