seyyah
Advanced Member level 2
As you know loadcells generally work in an environment with lots of mechanical vibration. So the output signal of the loadcell also vibrates very much. Averaging the output slows the output very much. Can we eliminate/ filter out this vibration from the output wihout much loss of the response rate? Thanks in advance.
