Elf header file specific question
El_Paco
Member level 1
Member level 1
Did someone know for which processor the machine type 0x24 is defined in elf header section.
I know that the file is written for a 32 bit risc cpu.
It would nice if someone can help.
Many thanks forward,
El_Paco
Hi El_Paco,
Most probably this ELF machine type is for PPC. If you can send me the file then i will try to confirm.
regards,
pharos :)
Hi El_Paco!
Did you try "file" command under linux? It is determining type of a file, and processor for ELF binary ...
As:
file yourfilename
Best Wishes! klug.
