Elevator system's floor sensor selection
Ramesh_maharjan
Member level 2
Member level 2
elevator floor sensors
Which sensor will be suitable for the floor sensor of an elevator. Is is effective and reliable to use limit OR reed switch.
there is also possibility of using magnetic binary sensor but i don't know much about them.
Help me to solve this problem in sensor selection
sensors in elevator system
Why don't you use a photodiode instead.It's worth a try .Anyway your project is fabulous and very exciting
photo diode is not used because it is sensitive to light& temp. i.e it is effected by ambient
