T
treez
Hello,
We have a 700mA current source which we designed. It drives Banks of LEDs or resistors fine.
However, when we try to use the TTi "LD300" electronic load as a dummy load for our 700mA current source then it doesnt sink current from the 700mA current source.
Why is this?
TTi LD300 electronics load:
https://www.tti-test.com/products-tti/precision/electronic-load.htm
This electronic load works fine when we set it to a voltage (say 5V) and feed it with a 5R resistor, the other side of the resistor being connected to a 10V Voltage source, ..the LD300 sinks 1 amp as it should.
Why doesnt it work as a load for our 700mA current source?
We set the LD300 to 15V, so it should sink the 700mA and be 15V, but it doesnt do it. (we are trying to make the LD300 act like a 15V LED string..why won't it do it?)
Why is this?
