It is a design of simple electronically controlled power supply (1,3-16,3V 1,5A). It uses kit AVT 2672. Transformer used was removed from an Unitra TV set. Another kit AVT 2857 „Voltmeter/ammeter module with thermostat” can be used for measuring voltage, current and temperature on heat sink. Transformer from antenna power supply powers the voltmeter module. The front panel was made of a white sheet printed on a laser printer. That sheet was attached to the panel with a double-sided tape for carpets adn then covered with self-adhesive foil.
Pictures:
Link to original thread - Zasilacz sterowany elektronicznie 1,3-16,3V 1,5A
