electronic switch (help me please)
volkii
Newbie level 5
Newbie level 5
turkey
hi,
i found tihs circuit, but i dont think about resistors and capasitors values. how can i make this circuit. input voltage 220V- 240V
i draw this shema. but its not working. comment please
thanks
i think the gate voltage applied exceeds that of bt136 maximum.
(R5, D1 and R4)
other than that a suggestion is show in diagram N.C contact(S2) as closed normally.
first tanks for important comment. i see. you say that R4-R5 values must be up? and normally s2 switch closed on my circuit.
have you connected S1 as push-to-on switch ?
and S2 as push-to-off switch?
yes im sure about s1 and s2 switch... i think i have a problem about r4-r5
i assume that you have connected MT1 MT2 terminals properly.
now for a test change R3 330K to 330ohms .
there must be a load connected for proper operation.
