hemnath
Advanced Member level 3
I have a pressure pump which provides continuous pressure of 10 bar. I want to control the pressure from 0 to 10 bar. Using the regulator I can adjust it. But i want to do it using electronically.
my idea is, input pressure is fed to proportional valve and input pressure is sensed using the high precision pressure gauge which has a feedback to the controller circuit. When the input pressure reaches the set point which is set by the user, proportional valve closes the incoming pressure. incase if the pressure is slightly higher than setpoint value, there is another proportional valve which is used to vent the excess pressure. To control these proportional valve, should I use PID algorithm or any other algorithms?
proportional valve which i selected: https://www.clippard.com/products/electronic-valve-proportional-evp
Please tell me if I'm doing it correctly.
