Electronic Engineer Assistant
rickyjar
Member level 2
Member level 2
User “pitrek662” presents his program designed for every electronic engineer and not only. In this version, the main emphasis was put on fixing minor bugs and improving the interface. In next version, new functions and probably possibility to send fault databases with to the server will be added.
Changes with regard to the 2.0.9 version:
-Fixed bug "," for the systems with a dot as a decimal mark
-Fixed bug in calculation of a multi-layer coil
-Possibility to search for PDF elements in the database
-Added option of searching for specification data through Google’s “I’m Feeling Lucky”
-Added button enabling to report an error or change proposal within the program
-Small improvements in the AVR database
-Protection from typing letters in places where digits are supposed to be
-Removed buttons “licz [count]”, the program performs automatic calculation after entering all data
-Removed buttons “wyjdź [cancel]”
-Improvements in interface
-Other small improvements in the majority of the modules
It contains:
- Database, program and help file update via the Internet
- Calculation of inductance and size of a single- and multi-layer air coil
- AVR microcontrollers base with drawings
- PIC 8-bit microcontrollers base
- TDA systems base (acc. to TME.pl)
- Option of searching the Internet for specification data
- Option of searching online stores for components
- Conversion of frequency (Hz) into frequency (s) and other way round
- Decoding of color codes of resistors, capacitors and chokes
- Conversion of units
- A calculator of the NE555 system
- Calculation of a resistor for a LED diode
- Calculation of replacement resistance
- Calculation of Volt, Amper, Wat
- LPT port controlling
- A resistor voltage divider
- Conversion of wat into dBm
- Decoding of code of electronic elements (MIL)
- Possibility to initiate up to 5 defined external applications
- Matching values of resistors to E24 sequence
- Fault database
- A calculator for an operational amplifier
- A RS232Terminal
- Conversion of the numeral systems
- Calculations for the LM317/337/350 system
- Calculation of the required thermal resistance of a heat sink
- Searching E3...E192 sequences
- Check for upgrades while initializing the application
If anyone found a mistake or had an idea about what to add or change, feel free to contact me. Every message is important:!:
Link to original thread - Asystent elektronika v2.1.0
