Electronic engineer assistant v2.0.9
gres
Full Member level 4
Full Member level 4
What's new compare to v2.0.8?
- folder with 8-bit microcontrollers Microchip PIC
- application engine to count right temperature resistance of radiator
- better application engine for numerical system
- application engine for searching in E3...E192 sequence
- better application engine for "amplification, intensity, power"
- better application for unit calculate
- new icon and possible to minimalize to tray
- check for new versions at program start.
Consist:
- actualization data base, program and help file via internet
- calculate right inductance and dimensions air choke single and multilayer
- AVR microcontrollers base with draws
- folder with - bit microcontrollers PIC
- TDA cirquit base
- search of catalogue data at the internet
- findings elements at internet shops
- recalculate frequency into period and reverse
- uncode barcode of resistors, condensers, impedance coils
- recalculate units
- calculators of NE555 arrangement
- calculate resistor for LED diode
- calculate supplementary resistance
- calculate Volt, Ampere, Watt
- steering of LPT port
- resistory voltage divider
- calculate watt to dBm
- uncode codes of electronic elements (MIL)
- possibility to start 5 exterior applications
- correct set resistor attributes to E24 series
- base of errors
- calculator for operating amplifier
- RS232 terminal
- calculate numerical system
- calculate for grid LM317/337/350
- calculate correct termic resistance of radiator
- searching through E3...E192 sequence
- check for updates at application start
Originally text cames from
https://www.elektroda.pl/rtvforum/topic1453977.html
