electronic circuit calculation
johnson pay
Who can help me to calcurate the Vin ,and write down the step for me ,thanks:-o
@ johnson: It's got "4V" written next to the input, so the input is probably 4V.
@ everyone else: Warning: that picture's a 2MB download and the scribbling on the right is illegible even at full resolution.
To find the open circuit voltage, work the problem like this:
Open circuit, so the current in the 6 ohm resistor is zero, therefore the voltage drop across this resistor is zero
=> Open circuit voltage = voltage across the 2 ohm resistor.
Current around the loop V/R is 10V/(2 + 3 ohms) = 2A.
Voltage across 2 ohms with 2 amps flowing = IR = 2 Amps * 2 Ohms = 4V.
Regards, Dan.
The answer is 4v,vin is open circuit so the 6R is ignore ,open circuit current=0,voltage=0.
Thanks for your help godfreyl and Dan Mills.
Regards, Johnson.
