Electric bike design with 450W engine
gres
Full Member level 4
Full Member level 4
Electric bike
It's a upgrade of this bike.
I hope changes that i'm going to make will increase power 3 times.
I had electric engine 450W 36V.
Max range 30km
Top speed 40 km/h
Accumulators displacement 12Ah
Nominal viltage 40V
Distance made 270km
Disadvantages:
-unsteady transmission ( chain like to feel down),
-no gearbox,
-problems with uphills,
-too fast,
- high situated center of inertia,
- direct system of power transmission cause problems on downhills ( engine breaking).
Advantages:
-high range even without cycling,
- low current collection - 5A when 15 km/h
- very simple but with costs ( short life of bowls, axis, chains)
I would like to rebuilt:
- transmission
* neutral gear
* gearbox
* better torque
- lower the center of inertia
* accumulators under wheel
- Tighten construction
- paint
At the moment i'm waiting for cassete 80z to placed instead of cranks. After that i need to connect it with smaller one. At the end fix the engine.
Original text at : https://www.elektroda.pl/rtvforum/topic1443925.html?sid=6940edf5dcc68b48bbdfb8c3a577532a
Electric bike
nice bike.. may i try it someday?
Electric bike
man
I had a dream for a larger motorcycle
using some OTC Lithium Ion batteries that are
designed for a rechargeable lawnmower
a locking clutch lever to engage the cells with a mechanical switch when its ride time
and and motor controller
I never worked out the charging system or any #'s for power and weight and gearing
But
VERY NICE BIKE !
Re: Electric bike
nice one. Well done.
