mr_monster
Member level 4
I want to be able to record a signal on a plate that is made up of a metal disc coated with an isolated oxide. The metal is grounded. A transistor with high voltage and current delivery capability is connected to a brush with discharges a small charge on the disc while it is moving. Another device with very high input impedance reads the signal from the disc after some distance (with some time delay). I have managed to make a prototype that works, however pretty badly. I have noticed that as I increase the output voltage the signal I get is starting to be louder and less distorted. The disc seems like a small 2 - 5pF capacitor at any given moment according to my LCR meter. Is the high voltage needed because the transistor has a hard time driving enough current to charge up the disc to a usable point? Can I do anything to lower the required voltage for this?
Thanks!
Thanks!
