Eldo's problem about tsmc 18 lib?
swgchlry
Member level 4
Member level 4
hspice warning dvt0
a circuit levle model of inverter:
Inverter Circuit
.param Supply=1.8 * Set value of Vdd
.lib '../lib/mm018.l' TT * Set 0.18um library
.opt scale=0.1u * Set lambda (here lambda=0.10)
.opt post
Vdd 1 0 'Supply'
Vin 2 0 pulse( 0 'Supply' td tr tf pw per )
.param td=5ns tr=1ns tf=2ns pw=4ns per=10ns
Mp 3 2 1 1 pch L=2 W=8 as=40 ps=4 ad=40 pd=8
Mn 3 2 0 0 nch L=2 W=4 as=20 ps=4 ad=20 pd=4
Cload 3 0 10fF
*transient analysis
.tran 50ps 50ns
*plotting requests
*.plot tran V(3)
.probe tran V(3)
.end
:cry:The probelm is:
I can simulate it in hspice 2007, but when i switch to eldo 6.1.1, i got following error message. I'm a beginner for spice and eldo, does antone can tell me why i got the err message, how to correct?
1*******28-Sep-07 ******* ELDO v6.6_1.1 (Engineering unqualified version) (v6.6_1.1) *******17:35:28******
0Inverter Circuit
0**** INPUT LISTING
0***********************************************************************
2 .PARAM SUPPLY=1.8 * SET VALUE OF VDD
3 .LIB ../lib/mm018.l TT
4 ** INCLUDING LIBRARY E:\circuit_sim\inv/../lib/mm018.l LIBTYPE=TT
1 .PARAM
2 +TOXN = 4.08E-09 TOXP = 4.08E-09
3 +DVTHN = 0 DVTHP = 0
4 +DXL = 0 DXW = 0
5 +CJN = 0.001000266 CJP = 0.001121
6 +CJSWN = 2.040547E-10 CJSWP = 2.481E-10
7 +CJSWGN = 3.340547E-10 CJSWGP = 4.221E-10
8 +CGON = 3.665E-10 CGOP = 3.28E-10
9 +HDIFN = 2E-07 HDIFP = 2E-07
10 .LIB mm018.l MOS
11 ** INCLUDING LIBRARY E:\circuit_sim\lib/mm018.l LIBTYPE=MOS
1 ***************************************************************
2 * *
3 * 1.8V MOS DEVICES MODEL *
4 * *
5 ***************************************************************
6 *
7 .MODEL NCH.1 NMOS ( LMIN = '1.2E-06-DXL'
8 +LMAX = 2.1E-05 WMIN = '1.01E-05-DXW' WMAX = 0.000101
9 +NLEV = 3 AF = 0.8256 KF = 9.326E-25
10 +LEVEL = 49 TNOM = 25 VERSION = 3.1
11 +TOX = TOXN XJ = 1.6E-07 NCH = 3.9E+17
12 +LLN = 1 LWN = 1 WLN = 1
13 +WWN = 1 LINT = 1E-08 LL = 0
14 +LW = 0 LWL = 0 WINT = 1E-08
15 +WL = 0 WW = 0 WWL = 0
16 +MOBMOD = 1 BINUNIT = 2 XL = '-2E-08+DXL'
17 +XW = '0+DXW' DWG = 0 DWB = 0
18 +ACM = 12 LDIF = 9E-08 HDIF = HDIFN
19 +RSH = 6.8 RD = 0 RS = 0
20 +VTH0 = '0.4452004+DVTHN' LVTH0 = 4.083943E-08 WVTH0 = -1.48489E-07
21 +PVTH0 = 1.993185E-13 K1 = 0.5099412 LK1 = 3.668304E-08
22 +WK1 = 2.766093E-08 PK1 = -2.19267E-13 K2 = 0.01695608
23 +LK2 = -1.755245E-08 WK2 = -1.034945E-08 PK2 = 6.480148E-14
24 +K3 = 0 DVT0 = 0 DVT1 = 0
25 +DVT2 = 0 DVT0W = 0 DVT1W = 0
26 +DVT2W = 0 NLX = 0 W0 = 0
27 +K3B = 0 VSAT = 90659.09 LVSAT = -0.006564545
28 +UA = -7.469327E-10 LUA = 2.025139E-16 WUA = 1.830494E-15
29 +PUA = -6.726249E-21 UB = 2.910666E-18 LUB = -1.955871E-25
30 +WUB = -6.764042E-24 PUB = 9.411708E-30 UC = 1.641302E-10
31 +LUC = -2.017381E-17 WUC = -5.974077E-16 PUC = 5.963958E-22
32 +RDSW = 170 PRWB = 0 PRWG = 0
33 +WR = 1 U0 = 0.04590562 LU0 = 3.578498E-09
34 +WU0 = -4.055627E-08 PU0 = -2.913943E-15 A0 = 0.2119483
35 +LA0 = -5.177149E-08 WA0 = 1.948019E-06 PA0 = -3.003349E-12
36 +KETA = -0.005987795 LKETA = -2.748571E-08 WKETA = 1.97602E-07
37 +PKETA = -1.586947E-13 A1 = 0 A2 = 0.99
38 +AGS = 0.02 B0 = 0 B1 = 0
39 +VOFF = -0.1498675 LVOFF = 4.906377E-09 WVOFF = 1.042303E-07
40 +PVOFF = -1.550514E-13 NFACTOR = 1 CIT = -0.0001267591
41 +LCIT = 2.665205E-10 CDSC = 0 CDSCB = 0
42 +CDSCD = 0 ETA0 = 5E-05 ETAB = -5E-05
43 +DSUB = 0 PCLM = 0.7736364 LPCLM = 2.625818E-07
44 +PDIBLC1 = 1E-06 PDIBLC2 = 0.0003968181 LPDIBLC2 = 3.019691E-09
45 +PDIBLCB = 0.01 DROUT = 0 PSCBE1 = 1.736364E+08
46 +LPSCBE1 = 262.5818 PSCBE2 = 1E-06 PVAG = 0
47 +DELTA = 0.01 ALPHA0 = 6.27411E-08 BETA0 = 11.59263
48 +KT1 = -0.2281038 LKT1 = 1.487402E-08 WKT1 = 4.09886E-08
49 +PKT1 = -1.499301E-13 KT2 = -0.02603289 LKT2 = 8.023716E-10
50 +WKT2 = -4.269E-08 PKT2 = -8.087905E-15 AT = 20000
51 +UTE = -1.606637 LUTE = 4.379861E-08 WUTE = 2.685053E-07
52 +PUTE = -4.4149E-13 UA1 = 1.224E-09 UB1 = -1.459973E-18
53 +LUB1 = 5.961568E-25 WUB1 = 3.423235E-24 PUB1 = -6.00926E-30
54 +UC1 = -5.990395E-11 LUC1 = 1.037438E-16 WUC1 = 7.225532E-16
55 +PUC1 = -1.045737E-21 KT1L = 0 PRT = 0
56 +CJ = CJN PB = 0.6882682 MJ = 0.3595262
57 +CJSW = CJSWN PBSW = 0.6882682 MJSW = 0.2003879
58 +CJSWG = CJSWGN PBSWG = 0.6882682 MJSWG = 0.43879
59 +CGDO = CGON CGSO = CGON CTA = 0.001040287
60 +CTP = 0.000645489 PTA = 0.001554306 PTP = 0.001554306
61 +JS = 8.38E-06 JSW = 1.6E-11 N = 1
62 +XTI = 3 CAPMOD = 0 NQSMOD = 0
63 +XPART = 1 CF = 0 TLEV = 1
64 +TLEVC = 1 CALCACM = 1 SFVTFLAG = 0
65 +VFBFLAG = 1 DLC = 3E-9 )
66
67
ERROR 545: MODEL "NCH.1": This level is not supported yet.
68 .MODEL NCH.2 NMOS ( LMIN = '5E-07-DXL'
69 +LMAX = '1.2E-06-DXL' WMIN = '1.01E-05-DXW' WMAX = 0.000101
70 +NLEV = 3 AF = 0.8256 KF = 9.326E-25
71 +LEVEL = 49 TNOM = 25 VERSION = 3.1
72 +TOX = TOXN XJ = 1.6E-07 NCH = 3.9E+17
73 +LLN = 1 LWN = 1 WLN = 1
74 +WWN = 1 LINT = 1E-08 LL = 0
75 +LW = 0 LWL = 0 WINT = 1E-08
76 +WL = 0 WW = 0 WWL = 0
77 +MOBMOD = 1 BINUNIT = 2 XL = '-2E-08+DXL'
78 +XW = '0+DXW' DWG = 0 DWB = 0
79 +ACM = 12 LDIF = 9E-08 HDIF = HDIFN
80 +RSH = 6.8 RD = 0 RS = 0
81 +VTH0 = '0.4690217+DVTHN' LVTH0 = 1.320675E-08 WVTH0 = 1.03913E-07
82 +PVTH0 = -9.346779E-14 K1 = 0.5348862 LK1 = 7.746888E-09
83 +WK1 = -3.099871E-08 PK1 = -1.512218E-13 K2 = 0.005167292
84 +LK2 = -3.877456E-09 WK2 = -3.134034E-09 PK2 = 5.643159E-14
85 +K3 = 0 DVT0 = 0 DVT1 = 0
86 +DVT2 = 0 DVT0W = 0 DVT1W = 0
87 +DVT2W = 0 NLX = 0 W0 = 0
88 +K3B = 0 VSAT = 85657.14 LVSAT = -0.0007622857
89 +UA = -4.439753E-10 LUA = -1.489168E-16 WUA = -5.953859E-15
90 +PUA = 2.303602E-21 UB = 2.349393E-18 LUB = 4.554895E-25
91 +WUB = 6.663095E-24 PUB = -6.163771E-30 UC = 9.496897E-11
92 +LUC = 6.005324E-17 WUC = 5.22306E-16 PUC = -7.024722E-22
93 +RDSW = 170 PRWB = 0 PRWG = 0
94 +WR = 1 U0 = 0.04780528 LU0 = 1.374896E-09
95 +WU0 = -4.015433E-08 PU0 = -3.380197E-15 A0 = 0.1270388
96 +LA0 = 4.67235E-08 WA0 = -4.21675E-06 PA0 = 4.147783E-12
97 +KETA = -0.02483604 LKETA = -5.621754E-09 WKETA = 8.9844E-08
98 +PKETA = -3.369537E-14 A1 = 0 A2 = 0.99
99 +AGS = 0.017056 LAGS = 3.41504E-09 WAGS = 2.946355E-07
100 +PAGS = -3.417772E-13 B0 = 0 B1 = 0
101 +VOFF = -0.1517648 LVOFF = 7.107172E-09 WVOFF = -1.044416E-07
102 +PVOFF = 8.700798E-14 NFACTOR = 1 CIT = -0.0001578858
103 +LCIT = 3.026274E-10 CDSC = 0 CDSCB = 0
104 +CDSCD = 0 ETA0 = 1.714285E-05 LETA0 = 3.811429E-11
105 +ETAB = -1.714285E-05 LETAB = -3.811429E-11 DSUB = 0
106 +PCLM = 0.8685714 LPCLM = 1.524572E-07 PDIBLC1 = 1E-06
107 +PDIBLC2 = 0.001685714 LPDIBLC2 = 1.524571E-09 PDIBLCB = 0.01
108 +DROUT = 0 PSCBE1 = 4E+08 PSCBE2 = 1E-06
109 +PVAG = 0 DELTA = 0.01 ALPHA0 = 6.27411E-08
110 +BETA0 = 11.59263 KT1 = -0.223624 LKT1 = 9.677446E-09
111 +WKT1 = -5.442481E-08 PKT1 = -3.925055E-14 KT2 = -0.02933674
112 +LKT2 = 4.634833E-09 WKT2 = -2.291865E-08 PKT2 = -3.102267E-14
113 +AT = 20000 UTE = -1.638485 LUTE = 8.074134E-08
114 +WUTE = 2.907924E-06 PUTE = -3.503216E-12 UA1 = 1.223706E-09
115 +LUA1 = 3.415059E-19 WUA1 = 2.946371E-17 PUA1 = -3.417791E-23
116 +UB1 = -1.198842E-18 LUB1 = 2.932454E-25 WUB1 = 1.123821E-23
117 +PUB1 = -1.507463E-29 UC1 = 1.573038E-11 LUC1 = 1.600793E-17
118 +WUC1 = 5.277456E-16 PUC1 = -8.197604E-22 KT1L = 0
119 +PRT = 0 CJ = CJN PB = 0.6882682
120 +MJ = 0.3595262 CJSW = CJSWN PBSW = 0.6882682
121 +MJSW = 0.2003879 CJSWG = CJSWGN PBSWG = 0.6882682
122 +MJSWG = 0.43879 CGDO = CGON CGSO = CGON
123 +CTA = 0.001040287 CTP = 0.000645489 PTA = 0.001554306
124 +PTP = 0.001554306 JS = 8.38E-06 JSW = 1.6E-11
125 +N = 1 XTI = 3 CAPMOD = 0
126 +NQSMOD = 0 XPART = 1 CF = 0
127 +TLEV = 1 TLEVC = 1 CALCACM = 1
128 +SFVTFLAG= 0 VFBFLAG = 1 DLC = 3E-9 )
129
130
Warning 902: "NLEV in model NCH.2": Model parameter ignored.
Warning 902: "AF in model NCH.2": Model parameter ignored.
Warning 902: "KF in model NCH.2": Model parameter ignored.
Warning 902: "VERSION in model NCH.2": Model parameter ignored.
Warning 902: "TOX in model NCH.2": Model parameter ignored.
Warning 902: "XJ in model NCH.2": Model parameter ignored.
Warning 902: "NCH in model NCH.2": Model parameter ignored.
Warning 902: "LLN in model NCH.2": Model parameter ignored.
Warning 902: "LWN in model NCH.2": Model parameter ignored.
Warning 902: "WLN in model NCH.2": Model parameter ignored.
Warning 902: "WWN in model NCH.2": Model parameter ignored.
Warning 902: "LINT in model NCH.2": Model parameter ignored.
Warning 902: "LL in model NCH.2": Model parameter ignored.
Warning 902: "LW in model NCH.2": Model parameter ignored.
Warning 902: "LWL in model NCH.2": Model parameter ignored.
Warning 902: "WINT in model NCH.2": Model parameter ignored.
Warning 902: "WL in model NCH.2": Model parameter ignored.
Warning 902: "WW in model NCH.2": Model parameter ignored.
Warning 902: "WWL in model NCH.2": Model parameter ignored.
Warning 902: "MOBMOD in model NCH.2": Model parameter ignored.
Warning 902: "BINUNIT in model NCH.2": Model parameter ignored.
Warning 902: "DWG in model NCH.2": Model parameter ignored.
Warning 902: "DWB in model NCH.2": Model parameter ignored.
Warning 902: "ACM in model NCH.2": Model parameter ignored.
Warning 902: "LDIF in model NCH.2": Model parameter ignored.
Warning 902: "HDIF in model NCH.2": Model parameter ignored.
Warning 902: "RSH in model NCH.2": Model parameter ignored.
Warning 902: "RD in model NCH.2": Model parameter ignored.
Warning 902: "RS in model NCH.2": Model parameter ignored.
Warning 902: "VTH0 in model NCH.2": Model parameter ignored.
Warning 902: "LVTH0 in model NCH.2": Model parameter ignored.
Warning 902: "WVTH0 in model NCH.2": Model parameter ignored.
Warning 902: "PVTH0 in model NCH.2": Model parameter ignored.
Warning 902: "K1 in model NCH.2": Model parameter ignored.
Warning 902: "LK1 in model NCH.2": Model parameter ignored.
Warning 902: "WK1 in model NCH.2": Model parameter ignored.
Warning 902: "PK1 in model NCH.2": Model parameter ignored.
Warning 902: "K2 in model NCH.2": Model parameter ignored.
Warning 902: "LK2 in model NCH.2": Model parameter ignored.
Warning 902: "WK2 in model NCH.2": Model parameter ignored.
Warning 902: "PK2 in model NCH.2": Model parameter ignored.
Warning 902: "K3 in model NCH.2": Model parameter ignored.
Warning 902: "DVT0 in model NCH.2": Model parameter ignored.
Warning 902: "DVT1 in model NCH.2": Model parameter ignored.
Warning 902: "DVT2 in model NCH.2": Model parameter ignored.
Warning 902: "DVT0W in model NCH.2": Model parameter ignored.
Warning 902: "DVT1W in model NCH.2": Model parameter ignored.
Warning 902: "DVT2W in model NCH.2": Model parameter ignored.
Warning 902: "NLX in model NCH.2": Model parameter ignored.
Warning 902: "W0 in model NCH.2": Model parameter ignored.
Warning 902: "K3B in model NCH.2": Model parameter ignored.
Warning 902: "VSAT in model NCH.2": Model parameter ignored.
Warning 902: "LVSAT in model NCH.2": Model parameter ignored.
Warning 902: "UA in model NCH.2": Model parameter ignored.
Warning 902: "LUA in model NCH.2": Model parameter ignored.
Warning 902: "WUA in model NCH.2": Model parameter ignored.
Warning 902: "PUA in model NCH.2": Model parameter ignored.
Warning 902: "UB in model NCH.2": Model parameter ignored.
Warning 902: "LUB in model NCH.2": Model parameter ignored.
Warning 902: "WUB in model NCH.2": Model parameter ignored.
Warning 902: "PUB in model NCH.2": Model parameter ignored.
Warning 902: "UC in model NCH.2": Model parameter ignored.
Warning 902: "LUC in model NCH.2": Model parameter ignored.
Warning 902: "WUC in model NCH.2": Model parameter ignored.
Warning 902: "PUC in model NCH.2": Model parameter ignored.
Warning 902: "RDSW in model NCH.2": Model parameter ignored.
Warning 902: "PRWB in model NCH.2": Model parameter ignored.
Warning 902: "PRWG in model NCH.2": Model parameter ignored.
Warning 902: "WR in model NCH.2": Model parameter ignored.
Warning 902: "U0 in model NCH.2": Model parameter ignored.
Warning 902: "LU0 in model NCH.2": Model parameter ignored.
Warning 902: "WU0 in model NCH.2": Model parameter ignored.
Warning 902: "PU0 in model NCH.2": Model parameter ignored.
Warning 902: "A0 in model NCH.2": Model parameter ignored.
Warning 902: "LA0 in model NCH.2": Model parameter ignored.
Warning 902: "WA0 in model NCH.2": Model parameter ignored.
Warning 902: "PA0 in model NCH.2": Model parameter ignored.
Warning 902: "KETA in model NCH.2": Model parameter ignored.
Warning 902: "LKETA in model NCH.2": Model parameter ignored.
Warning 902: "WKETA in model NCH.2": Model parameter ignored.
Warning 902: "PKETA in model NCH.2": Model parameter ignored.
Warning 902: "A1 in model NCH.2": Model parameter ignored.
Warning 902: "A2 in model NCH.2": Model parameter ignored.
Warning 902: "AGS in model NCH.2": Model parameter ignored.
Warning 902: "LAGS in model NCH.2": Model parameter ignored.
Warning 902: "WAGS in model NCH.2": Model parameter ignored.
Warning 902: "PAGS in model NCH.2": Model parameter ignored.
Warning 902: "B0 in model NCH.2": Model parameter ignored.
Warning 902: "B1 in model NCH.2": Model parameter ignored.
Warning 902: "VOFF in model NCH.2": Model parameter ignored.
Warning 902: "LVOFF in model NCH.2": Model parameter ignored.
Warning 902: "WVOFF in model NCH.2": Model parameter ignored.
Warning 902: "PVOFF in model NCH.2": Model parameter ignored.
Warning 902: "NFACTOR in model NCH.2": Model parameter ignored.
Warning 902: "CIT in model NCH.2": Model parameter ignored.
Warning 902: "LCIT in model NCH.2": Model parameter ignored.
Warning 902: "CDSC in model NCH.2": Model parameter ignored.
Warning 902: "CDSCB in model NCH.2": Model parameter ignored.
Warning 902: "CDSCD in model NCH.2": Model parameter ignored.
Warning 902: "ETA0 in model NCH.2": Model parameter ignored.
Warning 902: "LETA0 in model NCH.2": Model parameter ignored.
Warning 902: "ETAB in model NCH.2": Model parameter ignored.
Warning 902: "LETAB in model NCH.2": Model parameter ignored.
Warning 902: "DSUB in model NCH.2": Model parameter ignored.
Warning 902: "PCLM in model NCH.2": Model parameter ignored.
Warning 902: "LPCLM in model NCH.2": Model parameter ignored.
Warning 902: "PDIBLC1 in model NCH.2": Model parameter ignored.
Warning 902: "PDIBLC2 in model NCH.2": Model parameter ignored.
Warning 902: "LPDIBLC2 in model NCH.2": Model parameter ignored.
Warning 902: "PDIBLCB in model NCH.2": Model parameter ignored.
Warning 902: "DROUT in model NCH.2": Model parameter ignored.
Warning 902: "PSCBE1 in model NCH.2": Model parameter ignored.
Warning 902: "PSCBE2 in model NCH.2": Model parameter ignored.
Warning 902: "PVAG in model NCH.2": Model parameter ignored.
Warning 902: "DELTA in model NCH.2": Model parameter ignored.
Warning 902: "ALPHA0 in model NCH.2": Model parameter ignored.
Warning 902: "BETA0 in model NCH.2": Model parameter ignored.
Warning 902: "KT1 in model NCH.2": Model parameter ignored.
Warning 902: "LKT1 in model NCH.2": Model parameter ignored.
Warning 902: "WKT1 in model NCH.2": Model parameter ignored.
Warning 902: "PKT1 in model NCH.2": Model parameter ignored.
Warning 902: "KT2 in model NCH.2": Model parameter ignored.
Warning 902: "LKT2 in model NCH.2": Model parameter ignored.
Warning 902: "WKT2 in model NCH.2": Model parameter ignored.
Warning 902: "PKT2 in model NCH.2": Model parameter ignored.
Warning 902: "AT in model NCH.2": Model parameter ignored.
Warning 902: "UTE in model NCH.2": Model parameter ignored.
Warning 902: "LUTE in model NCH.2": Model parameter ignored.
Warning 902: "WUTE in model NCH.2": Model parameter ignored.
Warning 902: "PUTE in model NCH.2": Model parameter ignored.
Warning 902: "UA1 in model NCH.2": Model parameter ignored.
Warning 902: "LUA1 in model NCH.2": Model parameter ignored.
Warning 902: "WUA1 in model NCH.2": Model parameter ignored.
Warning 902: "PUA1 in model NCH.2": Model parameter ignored.
Warning 902: "UB1 in model NCH.2": Model parameter ignored.
Warning 902: "LUB1 in model NCH.2": Model parameter ignored.
Warning 902: "WUB1 in model NCH.2": Model parameter ignored.
Warning 902: "PUB1 in model NCH.2": Model parameter ignored.
Warning 902: "UC1 in model NCH.2": Model parameter ignored.
Warning 902: "LUC1 in model NCH.2": Model parameter ignored.
Warning 902: "WUC1 in model NCH.2": Model parameter ignored.
Warning 902: "PUC1 in model NCH.2": Model parameter ignored.
Warning 902: "KT1L in model NCH.2": Model parameter ignored.
Warning 902: "PRT in model NCH.2": Model parameter ignored.
Warning 902: "CJ in model NCH.2": Model parameter ignored.
Warning 902: "PB in model NCH.2": Model parameter ignored.
Warning 902: "MJ in model NCH.2": Model parameter ignored.
Warning 902: "CJSW in model NCH.2": Model parameter ignored.
Warning 902: "PBSW in model NCH.2": Model parameter ignored.
Warning 902: "MJSW in model NCH.2": Model parameter ignored.
Warning 902: "CJSWG in model NCH.2": Model parameter ignored.
Warning 902: "PBSWG in model NCH.2": Model parameter ignored.
Warning 902: "MJSWG in model NCH.2": Model parameter ignored.
Warning 902: "CGDO in model NCH.2": Model parameter ignored.
Warning 902: "CGSO in model NCH.2": Model parameter ignored.
Warning 902: "CTA in model NCH.2": Model parameter ignored.
Warning 902: "CTP in model NCH.2": Model parameter ignored.
Warning 902: "PTA in model NCH.2": Model parameter ignored.
Warning 902: "PTP in model NCH.2": Model parameter ignored.
Warning 902: "JS in model NCH.2": Model parameter ignored.
Warning 902: "JSW in model NCH.2": Model parameter ignored.
Warning 902: "N in model NCH.2": Model parameter ignored.
Warning 902: "XTI in model NCH.2": Model parameter ignored.
Warning 902: "CAPMOD in model NCH.2": Model parameter ignored.
Warning 902: "NQSMOD in model NCH.2": Model parameter ignored.
Warning 902: "XPART in model NCH.2": Model parameter ignored.
Warning 902: "CF in model NCH.2": Model parameter ignored.
Warning 902: "TLEV in model NCH.2": Model parameter ignored.
Warning 902: "TLEVC in model NCH.2": Model parameter ignored.
Warning 902: "CALCACM in model NCH.2": Model parameter ignored.
Warning 902: "SFVTFLAG in model NCH.2": Model parameter ignored.
Warning 902: "VFBFLAG in model NCH.2": Model parameter ignored.
Warning 902: "DLC in model NCH.2": Model parameter ignored.
mjswg tsmc parameter
I have found the problem! the lib is for spice, not eldo!
mos model parameter cjn
you can change LEVEL from 49 to 53 in model and try again...
bsim model in HSPICE call 49, in eldo - 53.
