evilheart
Member level 3
i am working on an embedded systems ethernet project , we are using micorchip ENC624J600 , i didn't design the PCB yet ,
but we have lack in components as we bought it from abroad and we don't have time to rebuy if they were damaged on failed protoypes , i have read several tips about designing PCB layout for ENC624J600 from the data sheet and other resources , i think the brief of it :
keep the TX and RX tracks straight and short , run them in pairs and make the pairs away from each other and every thing else
of course the same goes of course to SPI lines as well
is there other things i should consider ??? is there some standard tests to each part of circuit ??
the UART can be tested by loop back by i don't think that will work here because of addressing and all the complex stack stuff ,
how can i test the magnetics ??
is there some guide line for such applications ?
