gilbertomaldito
Full Member level 3
I have LED driver powered from AC source... I would like to know how to measure EFFiCIENCY of this circuit? Is this right:
Eff = Pave load / Pave ACsupply?
-my load is LED
-my Vac=110V 60Hz
-I just tried to get the Power ave of my load and my AC source. and divide them.
I get an eff of 20% .. I feel there is something wrong with my meausrement.
I am expecting to get more than 80%.
If you have a system like the LM3445 how to measure this efficiency. (**broken link removed**) - 1st page, you can see the system and efficiency graph on the lower right of the same page.
As you can see there is AC source then Bridge Rec and then the Buck regulator with LED as a LOAD.
-my load is LED
-my Vac=110V 60Hz
