ella1923
Member level 1
Usually a pullup & pulldown circuit is implemented in a circuit when one of the specifications of a design requires low standby current. Will this circuit affect the system stability in an LDO design? When is the proper way to design pullup/pulldown circuit?
Is this circuit (pullup/pulldown) need to be designed after obtaining all other design specifications or need to be designed while designing bias circuit?
Thank you,
ella
Thank you,
ella
