arunbharathi.arasu
Full Member level 2
- Joined
- Feb 28, 2013
- Messages
- 134
- Helped
- 7
- Reputation
- 14
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- Chennai, Tamil Nadu, India
- Activity points
- 2,151
Dear all,
Im using PIC18F4550, im writing some data to EEPROM.
Then read form the eeprom and write in to another memory.(Just Check)
i could not find any error in my code .
Please give me some suggestion. in proteus i'm seasoning EEPROM data.
Here is the code.
Here is the code.
// PIC18F4550 Configuration Bit Settings
// 'C' source line config statements
#include <htc.h>
//#pragma config CONFIG1L = 0x0
__CONFIG(1, PLLDIV_1 & CPUDIV_OSC1_PLL2 & USBDIV_1);
//#pragma config CONFIG1H = 0x5
__CONFIG(2, FOSC_EC_EC & FCMEN_OFF & IESO_OFF);
//#pragma config CONFIG2L = 0x1F
__CONFIG(3, PWRT_OFF & BOR_ON & BORV_3 & VREGEN_OFF);
//#pragma config CONFIG2H = 0x1E
__CONFIG(4, WDT_OFF & WDTPS_32768);
//#pragma config CONFIG3H = 0x2
__CONFIG(5, CCP2MX_OFF & PBADEN_ON & LPT1OSC_OFF & MCLRE_OFF);
//#pragma config CONFIG4L = 0x80
__CONFIG(6, STVREN_OFF & LVP_OFF & ICPRT_OFF & XINST_OFF);
//#pragma config CONFIG5L = 0xF
__CONFIG(7, CP0_OFF & CP1_OFF & CP2_OFF & CP3_OFF);
//#pragma config CONFIG5H = 0xC0
__CONFIG(8, CPB_OFF & CPD_OFF);
//#pragma config CONFIG6L = 0xF
__CONFIG(9, WRT0_OFF & WRT1_OFF & WRT2_OFF & WRT3_OFF);
//#pragma config CONFIG6H = 0x60
__CONFIG(10, WRTC_OFF & WRTB_OFF & WRTD_ON);
//#pragma config CONFIG7L = 0xF
__CONFIG(11, EBTR0_OFF & EBTR1_OFF & EBTR2_OFF & EBTR3_OFF);
//#pragma config CONFIG7H = 0x40
__CONFIG(12, EBTRB_OFF);
#include "strings.h"
unsigned char ReadData;
void delay(unsigned int de)
unsigned int maxde,minde;
for(maxde=0;maxde<de;maxde++)
for(minde=0;minde<453;minde++);
void Write_b_eep( unsigned int badd,unsigned char bdat )
//EEADR =0x00;
EEADR = (badd & 0x0ff);
EEDATA =bdat;
EECON1bits.EEPGD = 0;
EECON1bits.CFGS = 0;
EECON1bits.WREN = 1;
INTCONbits.GIE = 0;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1bits.WR = 1;
//while(EECON1bits.WR);
INTCONbits.GIE = 1;
EECON1bits.WREN = 0;
unsigned char Read_b_eep( unsigned int badd )
EECON1bits.RD = 1;
return( EEDATA ); // return with read byte
void main(void)
port1_init();
UART_init();
trans_string("PIC18F4550 EEPROM");
while(1)
Write_b_eep(0x0069,0x0010);
delay(100);
ReadData=Read_b_eep(0x0069);
delay(100);
Write_b_eep(0x006C,ReadData);
delay(1000);
