Jarakteri
Hi all,
My problem is this...
I use an Speemaster LV (in LPT1) and WinLV for uploading programs into eeprom(AM27C040, 512K x8). OS is windows XP.
I get verify error in address 0 when trying to upload .hex file to the eeprom. It manages to write a 0C in the first byte of the eeprom. The strange thing is that, if I write 0C to the first byte of the program I want to write to the eeprom, then the rest of the program writes succesfully, but of course the program dont work because of the wrong byte at the start. I measured the voltage on the Vpp pin and it showed ~12.8V while programming. It just flashes(~0.8V) when trying to program w/o the 0C in the begining of the program. Maybe insert 12.5V to Vpp pin?! :grin:
I have erased the eeproms under UV-Light and when read the memory is full of FF's, so there should'nt be a problem with faulty eeproms. Right? Programming device connected to the LPT1 port uses a 25cm long cable. I have two of these and the same issue occur with both of the cables. LPT1 port is runned in ECP mode.
The eeproms are quite old, but have worked in the past and I have programmed flash circuits(AM29F010B) with this setting w/o problems.
Any suggestions would be great.
- Jara
- Jara
