Editing technology file in ASITIC
mazelk
Full Member level 1
COLOMBIA
Hi
Is editing .tek file enough??
Inside a .tek file, what is the meaning of RSH, SMIN, WMIN, T, D for metals; RHO, T, and EPS for diff layers??
Is correct adding or deleting layers to .tek file as you need???
RSH= METAL SHEET RESITANCE
SMIN=MINIMUM SPACING BASED ON DRC RULES
WMIN=MINIMUM WIDTH
T=METAL THICKNESS
RHO=LAYER RESISTIVITY
T=LAYER THICJNESS
EPS= LAYER DIELECTRIC CONSTANT
YOU CAN MODIFY THE FILE BASED ON YOUR TECH FILE
