Editing PAL Video Signal
g_shyam1682
Full Member level 4
Full Member level 4
Udaipur-Rajshan-India
Hello friends
i design a cross bar Project
In which, i have edit PAL Video signal and make one horizontal and one vertical black line on CCTV Monitor
My hardware is
--PIC 18F4431, 20MHz Crystal
--LM1881
My Horizontal line is OK
But my vertical line is fluctuated,
i use polling programming to detect horizontal sync;
what is batter, Polling Programming or Interrupt programming to detect horizontal sync?
what is problem with my Vertical line?
Please Help me to find out my problem
You need to be using interrupts. Even so, I am not sure you will get a very stable vertical line using a microcontroller.
Keith
    g_shyam1682
    g_shyam1682
IanP said:
If you do it properly with interrupts I can’t see any reason why it shouldn’t be stable ..
It depends on your definition of stable. Interrupts have latency, which will vary depending on the exact timing of the interrupt relative to what the processor is doing at the time. The processor clock phase will vary within the line. If al these add up the less than the thickness of the vertical line you are generating then it might be good enough. For applications I have worked on I have generated a pixel clock phase locked to the line and driven the video with hardware (FPGA) so the image is rock solid.
Keith.
g_shyam1682 said:
Hello friends
My hardware is
--LM1881
I have used one 64uS Timer to edit Vertical line
it is work batter for one frame
but in next frame, position of vertical line is change
please, give me some hint or
some example code.
IN my project, PIC 18F4431 must be there.
In Pal tv signals the second field is interlaced and starts its progress scanning from the centre top of the screen not from the top left as the first field started.
Thank barrybear
Can you give me some Example "C" language code.
My Micro is PIC18F4431
