ro0ter
Junior Member level 3
- Joined
- Jan 14, 2012
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Cluj, Romania
- Activity points
- 1,656
Hello all,
I have received an Edimax 8-port switch from my sister that most certainly fed it 12v on its the 5v input... (I cannot guarantee that, but based on the damage I suppose that happened.. or maybe the PSU failed - I got no PSU).
The problem is quite straight-forward, there is a smd in a very strange package which is burnt. I took a picture which shows its marking code(s) very well then I touched it with a small screwdriver and indeed it scraped away, the plastics boiled (no soldering residue).
I have attached a picture to this post. The marking code on the piece is "3022" / "A10B". I couldn`t find anything regarding this piece (only some MOC3022.. but lol, there`s no AC... and a 3-pin TV diode, but to me it seems rather more a dc buck controller... not sure what voltage it outputs, as there is another SOT-89 "772" / "0A01" regulator closer to the IP178D, which may supply the 3v3... I would test whether the brains of this device are also fried, but since I don`t know the voltage it should output.. no chance... I will desolder it later on today and see if it has any marking code on its belly as well.
Anyway, this SMD piece is quite interesting, as you can see: the package seems to be SOT-89 but with extra 2 pins on both sides of the thicker pin... what in the world should that be?
Any help is highly appreciated, thank you very much!
NOTE: Allover the circuit there are 0R 1206 resistors used as inductors... (at least the board states Lx), none of which are toasted.
The resistor near the top-right capacitor in the photo is 010 (that is 1 ohm) and it seems just fine (didn`t measure it yet).
There is a huge inductor (33uh - the one to the left) connected to pins 1 and 3, a sk228 (5831a zener?) connected between pins 2 and 1.
+ input enters the pin 5 (last pin, e.g. pin 6, but since pin 2 is same as pin 5, I did not count it).
Any other questions there might be, please do ask.
SOT-89-5 is the package, as I have noticed on Farnel`s website (not sure if found product is relevant here, yet it is a led driver with switching frequency etc - **broken link removed**)
