fsnzr
I'm simulating a edge-coupled microstrip passband filter on 1.0mm alumina substrate with relative permittivity 9.9. I designed the filter and it's working just fine, I have almost exactly the desired frequency response. My problem is that in the final design i'm supposed to feed the filter with a 50ohm coax. I started off by just assigning a port straight to the first microstrip line thinking that I can change the feeding mechanism to a coax once i've got the desired response. Well, it turns out i'm not able to do it as easily as i had hoped. I thought id would be simple as i'm quite sure i've fed microstrip lines with coax's before by just simply connecting the center connector (used PEC) of the coax to the microstrip line. The desired passband is 5.9-6.1 GHz. I tested the coax's (I tried both air-filled and dielectric-filled) and they worked fine and had 50ohm impedance. What am I missing here?
Picture of the structure is attached. Z0 line is 1.2mm wide and thickness is 0.035mm. Material is PEC.
Thanks
Thanks
