6TheNightWhisper9
Newbie level 6
Dear All
I'v used Eclipse to create a simple AVr application for ATMEGA8A, but after compiling the code i got an errors which is generated with any avr application coded by the Eclipse,so pls help to solve these errors
my code is
and the errors are
and the details for the auto generated make file ,which contain the errors belong to subdir.mk file
and the toolchain configuration as below
many thanks
my code is
Code C - [expand] 1 2 3 4 5 6 7 8 9 #include <avr/io.h> int main() { DDRC |= 1<<PC0; while(1) { PORTC0 ^= 1<<PC0; } }
and the errors are
make: *** [LedOnOff.o] Error 1
recipe for target 'LedOnOff.o' failed
# Automatically-generated file. Do not edit!
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS += \
../LedOnOff.c
OBJS += \
./LedOnOff.o
C_DEPS += \
./LedOnOff.d
# Each subdirectory must supply rules for building sources it contributes
%.o: ../%.c
@echo 'Building file: $<' "the error is here"
@echo 'Invoking: AVR Compiler'
avr-gcc -Wall -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8a -DF_CPU=16000000UL -MMD -MP -MF"$(@:%.o=%.d)" -MT"$(@)" -c -o "$@" "$<"
@echo 'Finished building: $<'
@echo ' '
AVR-GCC C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin
GNU Make C:\Program Files (x86)\Atmel\Studio\7.0\shellutils
AVR Header Files C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include
AVRDude C:\Program Files (x86)\Arduino\hardware\tools\avr\bin
many thanks
