Fuses.
Input current to what, anyway?
The usb charger should have built-in current limiting.
The USB charger is probably switching between charging and not charging very fast - that is, current limiting. Perhaps the reason it does not switch like that when powered by your solar array is that the solar array produces less voltage than the car battery and so it can charge continuously without exceeding the current limit for the target device. That fast pulse charging you observe when connected to the car batter may be doing its job just fine. Does the target device get charged appropriately?Yes but its only for output current to load only. I have another circuit in another thread. When connected to small solar panel(low current), it can charged with no problem but connected to a car battery, usb charger does not charge at all and its shifts between charging to discharging modes very fast.
