pyrohaz
Member level 1
Hey guys,
I asked before about using rectangles in eagle and got a pretty good answer, i'd really appreciate it if you guys would help me out one last time on my PCB design.
My design is 4 pads on my PCB each with a 10meg resistor connected and a jumper. Its to use with the Arduino capacitive touch sensor code.
I've used rectangles to create the pads on the top layer and vias connected to "test pads" to connect the rectangles to the resistors on the underside.
I will include both schematic and PCB design. I'm using the Sparkfun eagle design rules.
I know that they spring up errors on "overlaps" which I presume are from the vias IN the test pads. Could somebody verify if this will be ok to send off to a PCB fab? I'm going to use PCBWing.
Thanks,
Harris
Thanks,
Harris
