Eagle question:drill vs diameter on vias
frank_eda
Newbie level 5
Newbie level 5
Hello,
What is the difference between drill and diameter in the vias settings?
Also if the "green" part of the vias overlap and they are tented, does that mean that the tents will overlap on the actual board?
drill is the finished size of the actual hole. diameter is the outer diameter of the copper surrounding the hole. The annular ring of the via will be the (diameter-drill)/2.
@mtwieg: then I am confused. The smallest settings for the diameter is .254mm. However, the smallest drill setting is .5mm.
Also if the green part overlaps on the board file will it overlap on the actual board?
Default settings refers to values of current technology in PCB manufacturing industry for drilling or corrode the copper. Don´t means that necessarily must exists relation between both minimum values.
Eagle gives you a drop down menu of many different sizes, but you're not restricted to those sizes, you can type in any number you want. 0.5mm drill hits are pretty big, most fabhouses can do 0.25mm no problem.
@mtwieg: thanks. How about the green part overlaps on the board file will it overlap on the actual board?
A via will be drilled my the manufacturer with a drill size 0.1mm larger than the finished via hole size. It is the FINISHED via hole size that you define in your EDA package. Refer to IPC-2221 and IPC-2222 for full details on this and other factors such as tolerance stack ups.
