Eagle pro.....Select and move a group not working.
T
treez
Newbie level 1
Hello,
I am laying out three PCBs in the same layout window. I need to do this as the pcbs will mechanically mesh together so at first i need to see them together. When i have finished i will put them each in there own window.
When i select one of the pcbs and try and move it over the other pcb to see how it fits, only the tracks and some of the silkscreen lettering moves, and the board dimension stays where it is, and the vias stay where they are, which as you know is wrong, when i select a window full of "stuff", everything in that window should be movable.
Do you know why only some of the things are movable?
I used to do this before and it worked fine...but not now.
