Eagle Pro..how get solder resist on bottom annulus only of via?
T
treez
Newbie level 1
Hello,
Please advise on this if you know?
Eagle only allows me to have both top and bottom annulus's covered , or not covered, in solder resist...is there a way round this? I am speaking of vias used in routing of tracks.
You can do this manually in board.
* switch all to "covered"
* put a circle (wire width = 0, diameter like desired) on layer "tStop" to "uncover" the desired vias on TOP side.
Or you can gererate it automatically with the CAM processor
* set all vias to be covered
* generate output file for bStop
* set all vial to be uncovered and
* generate output file for tStop
Maybe there are oter ways...
Klaus
ADDED:
Btw: CadSoft has a good forum and usually answer very fast on customer questions.
Reactions: mtwieg and treez
    T
    mtwieg
Eagle can't do this automatically, but this:
Is a very clever method to do what you want.
