kender
Colleagues,
I’d like to make a board where some of the vias are on SMT pads. I’m aware of the potential assembly problems, which via-in-pad might cause. My circuit will be hand assembled.
When I try to make via-in-pad, Eagle generates a pop-up message “can’t set via to layer 1”, or draws a big yellow X on the layout. Is it possible to suppress this error in Eagle layout :?:
I've set SMD & Via, SMD & Pad to 0 on the "Clearance" tab of the DRC. But, I keep getting the same error.
I'm aware of one workaround for this. A via can be drawn next to the pad and dragged to the pad afterwards. But, doing this for lots of pads would be a PITA.
Any suggestion, insight or reference is really appreciated!
Cheers,
- Nick
P.S. I'm not a newbie to PCB layout, but to Eagle I'm a newbie. Running 6.2.0 (free).
Cheers,
- Nick
