Eagle: IC pad design
PRASAN DUTT RAJU
Junior Member level 1
I'm designing the PBC layout of IC LPC1343 only its dedicated pad. But after going through all the process I'm stuck at Autorouter step as it is not able to optimize the the design. First I thought there may be reason that I've not given supply voltage & Ground that's why its not working but after adding both of two in schematic, once again the same problem has raised. It shows like this IC pad layout.jpg
My final layout should look like thislpc1343Adaptor.JPG.
My guess is that your autorouter setup is wrong.
1) Fine-pitch components should be aligned with the grid (all pads);
2) Routing grid should be (at least) equal the pitch of fine-pitch
components. If the pitch is not an exact routing grid multiple (ex.:
pitch=0.50mm and routing grid = 0.25mm), then you need a very small routing grid
to route the PCB.
3) DRC clearance should be smaller than the pitch minus the trace width
(space is needed for the trace to get to the pad). At least for the
clearance between the wires it should be in accordance to this rule.
Also have a look at this site:
https://intranet.ee.ic.ac.uk/t.clarke/eagle/Eagle_configuration.htm
I used manual routing because it's only 48 pin routing. However I've changed the shape. 1075086_10200432509960943_696356855_n.jpg
Now after production it's looking & working fine.
