Eagle does not give consistence between schematic and board
boncker
Member level 2
Member level 2
Brazil
eagle part not found in board
Guys,
I am working in Eagle software to make a schematic and switching to the board to place the components in correct place. So, I checked all inconsistences warnings but with 2 components it can not add to the board from schematic. See ERC message below:
Parts not found in board:
D2
REDE_60HZ
D2 (a diode) and REDE_60Hz (a pin) don't go to the board.
Anyone can help me how to include these D2 and REDE_60Hz on the board?
Thanks!
eagle update board from schematic
- delete these two components from the schematic
- be sure to have the board opened in the background
- place again the two components into the schematic
- do an ERC
another possibility if you didn't route anything in the board yet:
- close the board
- delete the *.brd file
- open the schematic if necessary
- switch to the board. As there is no board file, a new one will be created
Reactions: Naponus
    boncker
    Naponus
eagle not found in board
M!k,
I deleted the .brd file and did all again. Now it's running ok.
Thanks!
