notfet
Junior Member level 2
I have made many boards in Eagle using the Toner Transfer method. While eventually I would get a good board the trial and error took too much time. I prefer buying presensitized boards, Printing both sides on transperancy paper, Expose, Develop, And etch. I have had 100% success after my learning curve with a couple of exceptions that i need help with.
1. All the traces come out perfect results but the laser printer Grey's all the pads and I have tried longer or shorter exposure times. Neither make a difference. the result is a hatched copper pad that is hard to solder or if the pad is small it is missing entirely vias included too. I have tried >Change>pad etc. still the same.
2. on the same principal, Small IC pads don't develop very well and also hard to solder. Some Dil pads are oblong and turn out well it is the small pads that do not. Again I have tried Change --Pad with no results. I may be able to edit the library part but that may be tedious.
Any suggestions?
Any suggestions?
