Eagle 4.11 inverted printout
otuzsubat
Member level 4
Member level 4
istanbul, Turkey
how can i obtain the inverted printout in eagle 4.11?
normaly buses are in black color and space on pcb is white. i need inverse of this.
Options->User interface
Mr.Cube
Hello otuzsubat,
You can set up the colour scheme in schematic or layout by “Display/hide layers…” under “View” in the main menu. Then choose a layer and click “Change”. The background colour can be changed from the “Control Panel” under “Options -> User interface…”.
Bye,
cube007
i tried the changes which you tell about. but they change colors only in diplay. i want to change colors on printouted paper.
for example i changed background to black, and the wire and pads to white. then, i printed the document. but in paper background is white, wire and pads are black.
8) Use the cam processor and print using the PS inverted command, then open the file using adobe and print it.
